Results 1 to 17 of 17
Thread: 400+ hp miata for sale
    Chassis Designer BoostedNB's Avatar
    Apr 2006
    ft worth tx
    Default 400+ hp miata for sale
    Hello Everyone. I am regretfully selling my fully built custom turbo 450 hp Miata with only 1500 (thats right only fifteen hundred miles) New motor, turbo kit, suspension, and brakes. I have just ran into some financial problems and have to get rid of it. If it doesnt sell whole, then I am willing to part it out. Here are some pics. I will throw up a mod list later this evening.
    that miata > financial problems!
    Black 2002 Honda S2000
    Black 2003 Honda CBR 600 RR
    Asking Price = ????
    '06 RSX Type-S NBP
    Quote Originally Posted by Nexus Flux View Post
    Asking Price = ????
    There was a thread about it on the pointy board that mentioned $35k. It is a lot will be very hard to get, but I am sure he has a lot more than that into it. The new built long block alone likely cost him around $7500, it has a $3500 Motec, and a list of about a hundred other top price mods.
    Apr 2006
    ft worth tx
    I think that it might be very difficult to get the 35k for it so I am asking 25k firm. Thats just as little as I can take for it. I have about 60k in the car. The FM Long block was 9400 alone. turbo kit was about 8000. EMS with wiring harness was about 4800. I think that 25k is a steal for a miata of this caliber.
    Good Luck with that. My experience is you never get any where near what you put into it. Maybe you'll find a buyer that could justify it though.
    Even if you do find a willing buyer, the other issue is not to many people have $25k lying around and no bank will lend you anywhere near that on a 99-00 Miata.
    Nice car and I appreciate your effort but I think you're in for a reality check.
    Man, sorry to see you let go of this car. Stick to your guns. This car is worth way more than 25k to a lot of people. It's just perfect and it doesn't look like you cut any corners in building it.
    I'd hate to see you part out the car, so good luck with the sale.
    Thomas
    V-to-the-Dub
    Feb 2004
    The Enclave at The Villages of Deer Run at Quail Arroyo Estates de Chandelier Crossing
    Blog Entries
    1
    Quote Originally Posted by BoostedNB
    Quote Originally Posted by black roadster
    Not many people are in the market for a 400+hp Miata either, but the few that are would LOVE to find a deal like this and, knowing the build costs, will not balk at the asking price. The seller is already prepared to face the music, why take swipes at him?
    BoostedNB, good luck. I think the buyer, once you find them, will be very happy with that car.
    Last edited by redmenace; 08-26-2006 at 09:53 AM. Reason: The first draft of anything is crap.
    Specs on the car that he posted on the Pointy board:
    Engine:
    Complete Flyin Miata built long block including:
    FM Lightened Knife edged and Balanced Crank
    Carrillo H Beam Rods
    ARP Lower end studs
    FM Billet Main Crank Girdle
    Weiseco 9.1 Compression pistons
    ARP Head bolts
    Oil pump
    Multi angle valve job
    Port and polished headwork
    Unshrowded valves and combustion chamber lip
    polished combustion chamber
    1mm over on intake and exhaust valves
    FM valve springs and retainers
    FM adjustable cam gear
    FM aluminum radiator
    Vishnu fuel rail
    1000cc injectors
    MoTeC M4 stand alone EMS
    Custom wiring harness built by Tony Palo
    All fire resistant heat shrink
    All hard lines from radiator to turbo for coolant feed
    and return.
    Hard lines for oil feed and return
    Walboro intank unit
    Custom built tubular Stainless turbo manifold
    Full Race spec garret gt30R
    TIAL 44mm Wastegate
    TIAL 50mm blow off valve
    Custom 3 in downpipe
    Custom wastegate dump tube (to atmosphere)
    Custom 3 in full exhast with Apexi Muffler
    Custom 2 1/2 in intercooler piping
    Precision 24in x 12in x 3 in Intercooler core with
    custom endtanks
    FM Flywheel
    Competition 4 puck sprung clutch
    Redline MTL shock proof gear oil
    Redline Diff fluid
    FM Clutch Line
    Interior:
    Dual A pillar guage pod
    GReddy Trust boost guage
    GReddy Trust Exhaust Gas Temp guage
    Sparco Ring Suede steering wheel
    Bobby archer miata steering whee quick release
    Sparco Carbon shift knob
    Sparco Carbon pedals
    Sparco Fire Extinguisher
    Sparco Roadster Seats
    Crow Enterprises 5 pt harnesses
    Black floormats
    Custom LED shift light
    Clifford Alarm with proximity sensors
    Suspension and Brakes:
    Tein Flex coilovers
    Custom tranny brace
    Racing beat rear stabalizer brace
    Hard Dog Hard Core Double Diagonal Roll Bar
    FM Wilwood 4 piston caliper 4 wheel 2pc rotor big
    brake kit, with hard lines.
    Skunk 2 Titanium lug nuts
    16 in x 7.5 in SSR Competition wheels
    215 40 16 Goodyear directional tires
    Exterior:
    Custom Silver Flake Pearl paint
    Garage Vary Urethane lip
    Shaved emblems
    Apr 2006
    ft worth tx
    Thanks for posting the parts list Titus. I was trying to get around to that. The car makes 315 on 12 pounds on pump gas with tons of timing removed. it is extremely conservative. I have not put any race gas in the car yet. It has not even been to the track. This setup is built for close if not slightly over
    500 hp. Even with the lofty power goals I had in mind, it hits full boost at 3900 rpm and holds power till over 8000. I set the rev limiter to 7800 for good measure however. Thanks for all the positive feedback. And 25000 might be alot for a Miata, but a setup like this drivetrain alone with turbo and ecu would cost more than that. Keep in mind that it has less than 2000 miles on complete vehicle rebuild.
    Let me know if you end up parting out.. I may want dibs on a few things.
    '99 FMII + everything (sold!)
    '97 FMII (previously)
    Same here about parting it out, I would like some stuff too but I really DO hope you sell it complete.
    Very nice car.
    99 Miata Black
    Wow, that's a hell of a build. Wouldn't by chance be interested in a stock 05 RX8 trade would you
    VW Bug in running shoes
    M Porcupine sedan
    M Porcupine coupe
    Crusty old e46 beater
    Battery Powered appliance car
    Apr 2006
    ft worth tx
    Send pics.
    Quote Originally Posted by BoostedNB View Post
    Send pics.
    It's bone stock, sport package, appearance package, rotary accents, blue on black.
    http://s40.photobucket.com/albums/e218/Eosphoto/RX8/
    M Porcupine sedan
    M Porcupine coupe
    Quote Originally Posted by Shoefly View Post
    What -- did you blow up another engine? <hehehe>
  1. NC write-up in the Startle-Gram...
    By sammm in forum Miata Tech and Chat
    Last Post: 05-19-2007, 12:41 AM
  2. Miata Pics at Plano
    By Mouglie in forum Miata Tech and Chat
    Last Post: 04-05-2006, 03:20 AM
  3. Autoweek on the 2006 Miata
    By Kestrel in forum Bull
    Last Post: 07-29-2005, 05:06 PM
  4. Miata vs. Exploder
    By Jiggerachi in forum Bull
    Last Post: 07-01-2005, 11:28 AM
  5. Driver Death Rates...Miata
    By general default in forum Miata Tech and Chat
    Last Post: 05-10-2004, 06:10 PM
