Don't worry... no matter how gentle you are, it will break.
Well, I broke down and picked up some supplies a little while ago to repaint my brake calipers (from red to black) and my front bumper lip (redoing the stripes and a bunch of cracked areas) and some of my interior. It's going well so far, I'm almost done with the left brakes and about 1/3rd through the lip. I'm not really getting detailed because I'll probably have the entire thing repainted at some point... again. This was a CRAPPY job.
Anyway, about the interior.
How in the HECK to do you get the gauge hood off?
I've tried and tried, but even though I undo both Philips screws under the bottom, it won't come apart and I'm afraid I'll break it. Any help?? This is getting annoying
09 Lexus RX350
.... no Miata
09 Lexus RX350
.... no Miata
Er... the gauge hood, not that thingy covering the engine bay
EDIT: Another question. Is there a writeup on removing and replacing all the interior carpet? I don't want to dive into something without knowing what I'm getting into. I'm not going to remove the dash to replace it... I know it's possible!
Next Question: Where do I put the lubricant for the speedometer cable? I removed the gauge cluster and I believe I know the answer (in the hole, duh) but I want to make sure. Any suggestion on the type of lube to use?
Thanks guys. She's coming together
09 Lexus RX350
.... no Miata
Denatured alcohol will remove the overspray, if that is what you are describing as "from the painting". If you have painted it, and now want to remove the paint (from the plastic), better off just painting stock color (or color of choice). I have tried lacquer thinners in the past, they work, but too well....turns surface of plastic into a guey mess. Some PVC's can handle it, but I wouldn't trust ruining a good cluster hood. Also, did your hood have three clips, the "book" mentioned these, but did not show how to release them or WHEN to undo them. Good luck getting it together.
Second suggestion to your edit: All the carpet can be replaced without removing the dash...it is more difficult, but can be done. Hope you have some small monkeys available. Ha! The only downside is the carpet plugs (those little rubber things that stick in through holes to hold it in place) Those usually end up getting destroyed by removal. Some hardware stores carry them and are way cheaper than the dealer.
Thank you... now to find some graphite.. I suppose I could grind up a golf club shaft...
Actually I haven't painted it; I'm preparing to paint it. It had some scratches and chips off the stock paint.
The top of the hood is okay, but down around the edges the paint is sticky and rubbery (when I rub it, some of the paint will stay on my finger). I was wondering if there some way to get rid of it so I didn't have to paint over that mess.
I found some plugs at Autozone that look like they'll work; I'm going to take one of mine in just to be sure though.
As of now, the brake calipers have been repainted and look much, much better (the car colors match great now).
The front lip looks WAY better than it did, previously it had a ton of chips, dings, cracks, smudges, etc. I gave it a quick sand and masked it (the stripes extend onto it), then blasted it with cheap $2.50-can spray paint. It looks nice, and you can even see your reflection in it! I didn't go into a lot of detail because I'll probably get it repainted when I save up a bit of money.
I'm thinking a bass-boat dark metallic blue with 2 white stripes....
09 Lexus RX350
.... no Miata
Lock Smith dry lube is grafite. Should be able to get it at autozone or Home Depot in a little container for a buck or two.
You could also take a pencil and shave the lead out of it.
AUUUUUUUUUUUUUUGH.
Well gee, maybe I could do all this carpet stuff that I'm planning if SOMEBODY hadn't piled the #$% garage full of lawn tools, construction equipment, and other assorted CRAP. I can't even find my carpet and it was in a BIG box, WTF???
My brother: "Ooh I'll tell ya what, we'll each take half the garage, I'll take the front and you can have the back"
Me: "Okay" *suspicious*
A month later, my RC planes were being squeezed out by "necessities" and I'd be finding $1k worth of planes being stacked on each other and piled in corners.
I'm ticked.
Somebody cheer me up
09 Lexus RX350
.... no Miata
I have 4 kids, and that happens to me all time.... not w/ the planes though. I feel I'm being squeezed out by necessity.... Does that helP? :)
Sounds like some Denatured Alcohol might get rid of the gooey stuff and allow you to prep for painting. Denatured A is good for any painting prep as it creates a static repellent to block dust for a bit....
Michael
1990 Classic Red "C" Package with Hardtop.
1990 White project from Heck!
I am full of good ideas, just most people don't call it good ideas!
Update: Speedometer squeak is FIXED!!! The graphite worked perfectly. And my carpet was located in the backyard toolshed.
Unfortunately, the gauge hood did break on the way back in. But... er... I found out it was actually broken before I even tried to take it off No wonder it was so easy!! Now it looks like I'll need a new one.
Today: Carpet, lighted gauge faces, if there's enough time, headrest speakers. I'll be busy, hold my calls
Thanks again for the help, guys. Further bulletins as events warrant!!!
09 Lexus RX350
.... no Miata
QUESTION!
I need a power source for the lighted gauge faces. I'm working on them right now (veeery gingerly); what can I tie in to that will turn them on when the lights are turned on? I don't have a stinkin voltmeter
09 Lexus RX350
.... no Miata
Just hook them into the cigarette lighter and they will come on whenever the ignition is turned on. Otherwise, you could use the wire off of the stereo for the dimmer circuit.
