You should double-check on a warranty with this car. Do you still have the paperwork from the sale?
^Thanks..if disco'ing the cat doesn't fix it, next thing will be to pull the fuel pump and look in the tank.
With all the rain we've had, water in the gas would not surprise me!
If the was clogged wouldn't the problem be more pronounced at higher RPM's??
http://www.aa1car.com/library/converter.htmDriveability symptoms such as a drop in fuel economy, lack of high speed power, rough idle or stalling are classic symptoms of excessive backpressure due to a plugged converter. Checking exhaust backpressure and/or intake vacuum will tell you if there's a blockage
Pulled the cat and muffler yesterday, still intermittent sputter/loss of power. Pulled the fuel pump, and the gas is clear. I'm not sure where to go next.
When was the last time you replaced the fuel filter? Had a buddy with a car that had sediment that settled in the fuel filter. Once the car was underway, it would block flow and cause sputters and mis-fires. Took forever to figure it out because the car always started and ran fine initially. After stopping, the sediment would settle again and everything would be fine for the next start.
Originally Posted by Jeremy Clarkson
Currently:
1991 Mariner Blue (daily driver)
Previously:
1994 M-Edition
Fuel filter is < 1 year old. It will run fine, sputter for a bit, and then run fine again. I bench tested the coil pack, but maybe I should do that again.
Maybe its a "Feature" your going to have to learn to love.....
Cheater motor Karma?
How are the injector o-rings? Did you reuse your 93LE injectors?
I've thought about the injectors, they are new as mentioned. The main thing to remember is it started acting this way after one of the heater hoses was leaking.
The engine bay had a nice steam bath for a few minutes before I saw was what happening.
He shook them really hard. Never, never, never shake a baby injector.
